Bosch36pph 290155737 white
Old Sep 29, 2014 | 08:58 AM
dfarr67's Avatar
Any info on these regarding compenstions with EBL?
34.5 @ 43.5psi
Old Oct 1, 2014 | 08:21 AM
dfarr67's Avatar
Re: Bosch36pph 290155737 white
http://www.hptuners.com/forum/showth...6lb-0280155737
Just to close this one off in case others run across the same question. I have confirmed from a couple of different sources that all three part numbers - 0280155868, 0280155811, & 0280155737 are all the same injector. The reason for the different p/n's was actually different material and color of the o-rings (o-ring size is still the same across all 3).
'm curious for those of you that are using these injectors what your final high/low slope and breakpoint has turned out to be. I've played around a lot and it seems that I've settled on High Slope = 36.5008 and Low Slope = 47.2504 (lbs/hr) with a breakpoint of 3.65 x 10e-5 lb/rev. Because the spec sheet is in mass vs. rev, my understanding is that you need to multiple the spec sheet breakpoint x 4 and move the decimal places. I think this came from a decipha post.
File Type: pdf
File Type: pdf
File Type: pdf
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
89bird2.8
Sep 25, 2015 09:21 AM
KCG
Sep 23, 2015 09:05 AM
