USB Spliced obd1 reader.
Old Dec 12, 2014 | 08:03 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Is it possible to splice a usb cable open and run direct wire to the obd1 port and get a reading with tuner pro? If so which pins to I need to run the wire to?
Old Dec 12, 2014 | 08:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: USB Spliced obd1 reader.
You need more than just a USB cable a max232 will work on some ecms. You might want to specify what ECM your trying to connect to .
Old Dec 12, 2014 | 08:19 PM
factory 91 z28
Old Dec 18, 2014 | 11:26 PM
Engine: Lb9
Transmission: M20
http://aldlcables.com moates.net extreme aldl, reddevilriver will all work with a 1227730 ECM.
9192camaro
16
Feb 3, 2019 12:21 AM
327IROC85
Sep 23, 2015 12:11 AM
Tweeks25
Sep 17, 2015 08:04 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
