Will this ECM work in my Camaro?
Old Dec 19, 2014 | 06:33 PM
Lck119's Avatar
Car: 1989 RS
Engine: 2.8 V6
I have a 1989 RS, 2.8 litre V6. Struggling to come up with info on ECMs. Are they all the same etc.. I've found this on ebay, was wondering if it will work on my car? It says they are for TPI cars, is mine one of those? Or is MPFI different? Just wondering if I will be able to use this ECM on my car! Thank you!
http://www.ebay.ca/itm/86-89-or-90-9...7753f3&vxp=mtr
Old Dec 20, 2014 | 08:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Will this ECM work in my Camaro?
The link is to a re-programming service, not an ECM. The 2.8l MPFI ECM uses a separate PROM, not a MEMCAL, so it won't work.
The ECM in your '89 is the same from '86 through '89, it is the 1227302 ECM. It is only used in the 2.8l MPFI cars. The TBI and TPI cars used a different ECM.
RBob.
Old Dec 29, 2014 | 10:11 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
RBob is correct. I have the ECM you need out of my 89 2.8 if you are looking for one. Nothing wrong with it, converted to a Megasquirt ecm when I went turbo.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
armybyrd
Dec 5, 2015 09:22 AM
marcusaw
Aug 10, 2015 08:13 AM
