ECM Codes Won't Reset
Old Dec 25, 2014 | 05:53 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Anybody know why my ECM error codes won't reset by pulling the ECM Fuse? 92 RS -- I am traveling right now and its Xmas day so have no access to an 8 mm wrench to disconnect the battery cable...
Old Dec 26, 2014 | 09:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ECM Codes Won't Reset
The fuse to pull is the one under the hood. It is inline a wire on the passenger side that runs along the inner fender. Remove it for at least 10 minutes.
RBob.
Old Dec 26, 2014 | 02:06 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Thanks but I don't have an inline fuse anywhere to be found on either side. The only ECM fuse is in the fuse block. I picked up a wrench set this morning and pulled the battery cable and it reset fine.
Old Dec 26, 2014 | 04:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It's there, you just didn't find it yet. The ECM fuse in the fuse panel is for the ignition switched power to the ECM. The inline fuse powers the ECM along with providing power for RAM back up (during key-off).
The inline fuse also provides power for the fuel pump.
RBob.
Old Jan 4, 2015 | 08:43 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Ok, thanks.. I found it.. It was behind the carbon canister (my battery is on the driver side) just in front of the radiator overflow bottle and was hidden in a plastic mounting case bolted up under the edge of the fender.. Looked like a cable connector just plugged into a small relay.. Pulled the connector loose and it held the fuse inside it.. Neat way to hold the fuse but darn hard to find.. ECM codes reset ok by pulling it..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
