1987 firebird t5 vss problem
Old Feb 4, 2015 | 08:36 PM
chevy2424's Avatar
Hey guys I swapped a t5 into my firebird and it was from a camaro so the t5 has the cable drive speedo. I bought a 2k pulse adapter from painless wiring and my speedo isn't working now. my car is factory carbed car. Did I get the right adapter or did I need the 4k? now doing even more research I see some people saying the firebirds are 4k pulse or is that just for the tpi? I'm new to this stuff so any help would be appreciated greatly. Thanks
Old Feb 5, 2015 | 07:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1987 firebird t5 vss problem
I take it that the previous 700R4 had an electric VSS on the transmission? If so then you need a 4K PPM magnetic VSS for the T5. Also, under the dash should be a yellow box (sometimes white), on the passenger side that has "4-OUT BUFFER" on it.
Again, if there is, then the 4K PPM magnetic VSS is the correct one to use. The magnetic VSS is also referred to as a 'sine wave' output type.
RBob.
Old Feb 5, 2015 | 09:03 AM
chevy2424's Avatar
RBob.
Yeah it had the 700r4 with the vss explains why the speedo isn't working wrong vss adapter. Thanks for the response i appreciate it.
Old Nov 15, 2015 | 08:47 PM
gtandut's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Did you ever resolve this by chance? I am having the same problem. Swapped out my 700r4 auto with a t5 that is cable driven. Haven't figured out how to get my electronic speedo working. And I don't have the old transmission anymore to swap out the gears and vss.
Old Nov 16, 2015 | 06:01 AM
chevy2424's Avatar
Ya I figured it out I got a painless wiring speed sensor 4k ppm it'd a bit pricey but worked like a charm
TX-SleeperC5
Feb 24, 2016 01:34 PM
tyeo098
Nov 30, 2015 06:27 PM
bjpotter
Oct 4, 2015 07:48 PM
mcbitchman
Sep 29, 2015 12:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
