fuel pump issues
Old Feb 7, 2015 | 11:44 AM
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
Axle/Gears: 2.73 gears
fuel pump issues
ok I have a 91 Camaro 5.7tpi and last week I had to have the car towed back to the house because the fuel pump wouldn't prime and the battery died as well. got home and managed to get the car to start and run but still no fuel pump prime. what could cause this? I replaced the fuel pump relay and checked all fuses and everything seems to be ok. this car is driving me crazy. how could I check if it is the ecm or pump? could the priming part of the pump be bad but the pump itself be good? I was thinking about just running a jumper wire to the relay and just set prime on toggle switch, I really don't want to have to drop the gas tank again. please help
loco823's Avatar
Car: 91 Camaro
Engine: 5.7 v8
Re: fuel pump issues
oh the car has crate 350 with painless wiring harness 60103 in it
Old Feb 7, 2015 | 07:23 PM
ULTM8Z's Avatar
You need to verify the fuel pump works. If you can jump directly to 12V, that would verify it.
I also believe the oil pressure sensor is on the fuel pump circuit. Could also be the oil pressure sensor.
Old Feb 8, 2015 | 06:56 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
My fuel pump worked, but my fuel pressure regulator would not prime. Hard time starting car and ran rich after starting. After shutting off the fuel pressure would drop to zero in seconds. After repairing the pressure regulator the car is fine. Car primes and hold pressure and is not running rich.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
