will the computer from a 3.1 in a 92 Rs work in my 2.8 89 rs
Old Apr 7, 2015 | 01:54 AM
keepitpunk's Avatar
I just kind of have the computer and was wondering if it would hurt anything or if it would help anything
Old Apr 7, 2015 | 07:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: will the computer from a 3.1 in a 92 Rs work in my 2.8 89 rs
The '92 3.1l ECM ('7730) is not plug & play with the '89 2.8l '7302 ECM. You could use it with a complete re-pin of the ECM harness connectors, or swapping the proper harness in. Along with adding a MAP sensor.
RBob.
Old Apr 7, 2015 | 01:12 PM
keepitpunk's Avatar
so basically more work than it's worth?
Old Apr 7, 2015 | 01:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Six of one and a half-dozen of another. It really comes down to what you want from the ECM. If you are leaving the engine for the most part stock, and there aren't any MAF issues, it won't buy you a lot to change over to the '7730 ECM.
However, if you are going to boost the engine along with engine & driveline upgrades, that is a different story.
RBob.
jharrison5
Aug 19, 2015 05:53 PM
perZ
Aug 15, 2015 01:17 PM
matthew911
Aug 12, 2015 09:38 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
