ALDL question and 7730 ECM
Old Nov 7, 2001 | 04:22 PM
Chris Sartori's Avatar
Hi all,
Converted a 88(305TBI) to 91(350TPI)using all factory, harness and ECM. Engine starts and runs but is running very rich. I purchased a Autogalaxy scanner but when I plug it in the ALDL connection I get "No Data". But when I jumper to ground to check codes I get a code 12 six times. Anyone have any ideas or a direction to go in?
Thanks!
Old Nov 7, 2001 | 06:54 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
I would call the people who you bought it from. It sounds like it's just not connecting but the ecm is fine. If nothing works, build a cable and run Craig Moates software. The software is free and requires nothing more than a 386 and DOS to run. The cable can be built for next to nothing, too. Do a search on the DIY PROM board for info.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
