question about ECM codes
Old Nov 8, 2001 | 09:29 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
I have an 88 iroc, and I get the service engine light every once in a while. I put the key into the diagnostic connector and it says code 33, which means the MAF. But i already replaced that, the gasket for the throttlebody, and all the PVC lines. Its driving me nuts...what else could it be??
Old Nov 8, 2001 | 09:40 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
The samething happened to me. I ended up replacing both relays. There is two of them on the driver side firewall. It could also be a loose wire or plug on either the MAF sensor or the relays or both.
Old Nov 8, 2001 | 10:15 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
I was thinking about that, but I never got to them. And also the little black accordian thing the PVC tubes are hooked up to (vaacum) I might have thought becayse everytime I pushed it in a couple time it seemed to run good for a couple days.
specialized
Jun 18, 2022 09:26 AM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
