Memcal Troubles?
Old Nov 12, 2001 | 10:39 AM
Mojo's Avatar
Memcal Troubles?
Over the weekend, I finally put a battery back in my car, thinking I'd go for a drive this weekend. When I started it up it went straight into limp mode. I couldn't even get my laptop to link. I pulled the memcal and put it in the adaptor on my programmer, and found garbage on the eprom. Strange, no matter what I did, it would continually give off different readings. I took the chip off of the memcal and put it directly in the programmer. Problems disappeared. I put the chip back in the memcal, the memcal back on the adaptor and checked continuity for every pin. It all checked out, but still went crazy in the programmer. Now I'm confused?!? Any ideas?
Chris
408cid 1985 Corvette
http://www.mojosgarage.com
Old Nov 12, 2001 | 01:00 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Mojo:
Chris
</font>
There is a bad connection in the adapter, might just go thru and resolder every pin. I've had several do that, some even after months of use.
Old Nov 12, 2001 | 11:21 PM
Mojo's Avatar
Thanks Grumpy! I went back over the connections in the memcal with my multitester, and as usual, you were right!
88SS6SPEED
Nov 11, 2015 07:05 AM
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
lethaldomestics
Sep 21, 2015 01:18 PM
