Mismatched ECU and PROM
Old Apr 14, 2016 | 05:08 PM
dear1700's Avatar
Car: 83 Blazer
Engine: Camaro 305
I got a 305 bored .040 with an aftermarket cam. Was orginally out of an F-Body. It has no AIR injection, No A/C, and EGR blocked off. I don't have a functioning SES light either as the remote light never comes on.
Its currently in an 83 Blazer that was orginally a carbed 4cyl. Got heads at the machine shop currently, but when it was together it ran really crappy. I also didnt do the swap so I'm just going thru everything and just trying to get it to function properly at this point.
Anyway, the ECU that was installed is a 1227747 with a ACSU chip. My search showed that its out of a 350 L05, can someone confirm? Also, not sure what injectors were on it, but has new 305 injectors now. I can bump up pressure to accomodate the mods but need a fresh pump installed while heads are off. It doesnt build over 12psi with return line pinched. TPI pump a good/sufficient upgrade?
Also with this ECU would it be better to go with a Moates chip burner or an EBL ecu? I would rather not have to get a new harness if at all possible.
Many thanks!
Old Apr 16, 2016 | 04:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Mismatched ECU and PROM
That is correct. An '87 - '88 MY with a 700R4 transmission.
Lately the TPI Bosch brand pump is decent.
The EBL ECM is pin & plug compatible with your stock '7747 harness. Comparing a chip burner with the EBL is apples and oranges. One burns chips for tuning using the stock ECM & firmware. Plus the separate need for data logging.
An EBL system is integrated with Flash memory for the calibration/firmware, What's Up Display, documentation and so on.
RBob.
Old Apr 17, 2016 | 09:52 AM
dear1700's Avatar
Car: 83 Blazer
Engine: Camaro 305
RBob.[/QUOTE]
But when I went to the dynamic efi website, the ecm that was shown had different connections than my ecu. Even though these are different, I can desolder the existing daughterboard and resolder in the EBL one? Also, could I get by with a NB O2 sensor or is a WB absolutely necessary?
Old Apr 18, 2016 | 07:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are three different systems offered. The EBL Flash is the one that matches your '7747 ECM. There is no longer an EBL Flash self-install. You can either send your ECM in to have it converted or purchase a complete EBL Flash system with the ECM included.
It is recommended that the stock NB O2 sensor be retained. Then use a WB setup as an "add on" (if desired).
RBob.
Old Apr 18, 2016 | 02:17 PM
dear1700's Avatar
Car: 83 Blazer
Engine: Camaro 305
RBob.
Ok, thanks for setting me straight. I did see that section on the compatible ecu's. And thanks for the heads up on not doing the self-install. Thats fine if I have to send it out, waiting on heads to get done anyway.
And its not much more if any that trying to put a carb on it, which was plan B. And this will allow me to grow with my mods and swap over when I stuff 350 in eventually.
I'll be sure to read up on the tuning software. I've dabbled in it slightly with an old Megaquirt build with TunerStudio.
Sean Brereton
Sep 28, 2023 10:04 PM
Mattkovitch
Jun 6, 2016 09:35 AM
backtothe80s
Mar 29, 2016 01:02 PM
tonys91rs
Mar 27, 2016 06:04 AM
oscarfromla
Mar 20, 2016 10:10 PM
