305 ECM & TPI running on a GM crate 350
Old Oct 8, 2017 | 08:30 AM
Dwinn's Avatar
I purchased a sports car with a TPI 350 from an estate. The car seems to run great, is fast, with lots of torque. Initially I was lead to believe the engine was a 92 Camaro L98, but it turns out it is a GM crate motor (don't know that this is a big issue). The TPI is most likely from 1985 - 1988 since it has the Cold Start setup. In researching the TPI, I found that the previous owner had put in a toggle switch to bypass the cold start. The car runs fine, but I don't know if this might be an issue at some point. The interesting thing I found, is that the ECM is apparently for a 305. Again, don't know if this is be a problem. The outside of the ECM box says GM/ACD 88999194 LC21 490706298 GR 3 670 CG ESCM REMAN USA. The ECM is 1227165. The EPROM says AKFN 2178. I removed the MEMCAL (?) and the chip is marked 1606930, but the online info says it should be a 16082177. Couldn't find any info on the 16069300. Would I need to take it to a programmer to find out if it is custom programmed?
Old Oct 8, 2017 | 11:41 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 ECM & TPI running on a GM crate 350
The Akfn (88 5.0 auto) if it has the sticker intact it’s more than likely never been reprogrammed. A read can be done to compare the binary file to see if it’s stock. Most people switch to $6e 89 programming after a swap to illuminate the ninth injector. Send me a pm if you are needing a read or reprogramming.
Old Oct 9, 2017 | 08:58 AM
MrWillys's Avatar
If the silver sticker is on it then it is stock. Now is the time to consider upgrading your injectors before reprogramming. The 305 programming is holding back a lot of potential in your vehicle.
I won't pimp what I do as RBob will say I'm violating TOS. Just get the EBL and it will solve all your problems?
Old Oct 9, 2017 | 10:58 AM
Engine: Lb9
Transmission: M20
I guess I’m a pimp lol, I just offered to look at the .bin for shipping costs defines me as a pimp. We already discussed injector size thanks.
Old Oct 9, 2017 | 11:06 AM
MrWillys's Avatar
I have nothing but respect for you and my comments were not intended to offend you. Consider it a Player in a Management Position? I was being sarcastic towards some here though.
