ecm toast?
Old Dec 31, 2017 | 06:23 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ecm toast?
noticed other morning when I started it ses lite stayed on. shut it off. restarted it. same thing. I jumped a and b at the connector. fan didnt come on ses never flashed just stayed on. took jumper out in tried to start it back up. nothing just turnt over never started.
Old Dec 31, 2017 | 09:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ecm toast?
Sounds like it. Try this, do a key-on, engine-off while observing the SES light. It should turn on briefly, blink off, then turn on solid. Can repeat the test after at least 10 seconds of key-off.
The key is the blink off, it the SES doesn't do that then either the ECM or the PROM on the MEMCAL is bad.
RBob.
Old Dec 31, 2017 | 11:39 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: ecm toast?
also notice last 6 mths at first start, itd take 10 mins to warm up before it would idle down to 850rpm.
Old Jan 3, 2018 | 10:27 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: ecm toast?
tried it again. ses light blinks. but fan not coming on and no codes when a and b jumped.
Paul Riccioli Jr
May 24, 2001 06:21 AM
IROCeastTN
Feb 14, 2001 06:36 PM
