Question
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Question
Remove the bulb . You can also cut the brown/white stripe wire at pin e7 at the ecm. The ecm grounds the check engine light bulb when there is a malfunction.You need to retain the ecm it’s a vehicle speed buffer for the speedometer. Unless you get a buffer from a tpi maf or tbi car.
You can see that e7 is in the yellow connector at the ecm.
http://tpiparts.net/1227730_pinout_diagram
Last edited by Tuned Performance; Feb 5, 2018 at 12:32 PM. Reason: Additional information
'86 350
Carburetors
38
Oct 16, 2007 09:55 PM
easySPEEDcamaro
Feb 26, 2003 07:31 PM
whiterocz
Jul 5, 2001 11:08 PM
