Do I need closed loop?
Old May 20, 2018 | 06:23 PM
japery's Avatar
Car: 1977 corvette
Engine: 355 blueprint crate
Transmission: th200r4
Im running only in the summer months with a 77 vette with HSR and wondering if i really need closed loop? I dont have emissions to deal with and I dont have a good grasp on tuning. Can I turn it off some how?
Old May 20, 2018 | 07:58 PM
ULTM8Z's Avatar
Re: Do I need closed loop?
What year is your TPI system from? If its 90-92 you can run the SAUJP bin which has an open loop feature you can activate.
the thing is, switching to open loop isn't a cure all if you have tuning issues.
the only other way to do it is disconnect the O2 sensor, but thats likely to generate error codes.
Old May 21, 2018 | 07:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Easiest way to disable closed loop is to set this parameter to a high temperature:
L8489: FCB 120 ; 50C, (122F) MIN COOL FOR CLS LP
RBob.
Old May 21, 2018 | 08:27 AM
ULTM8Z's Avatar
Good point. Forgot about the temperature aspect of it.
Old May 21, 2018 | 02:50 PM
japery's Avatar
Car: 1977 corvette
Im using the 91 AUJP 1227730 ecm. Iv got the Moates hardware and Tunerpro RT software. Bought all that stuff but forgot that i cant understand any of it. Iv been slowly learning but still have major issues with the tune.
Old May 21, 2018 | 03:07 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I run in open loop all the time. Disabled it with temp setting. Since it's a performance build I wasn't looking for good mileage, and no emissions tests here either.
Made tuning so much easier.
Old May 21, 2018 | 07:29 PM
ULTM8Z's Avatar
I run open loop at idle, but that was after years of trying to dial in the Miniram idle and off-idle transition until I finally "flipped the bird" to the ECM and disabled closed loop idle... But you need S_AUJP to do that (I have mine set to go back into closed loop at 1500 rpm... when I'm fully out of idle).
Otherwise, you can disable closed loop as RBob suggested, but it disables it everywhere.
I whipped the non-idle, non-WOT operation into line by playing around with the O2 voltage thresholds to richen it up (kept wanting to give me a ~15.5:1 AFR as reported on the WB, even under moderate, non-power-enrichment acceleration). If it wasn't for that, I probably would have gone fully open loop as well. But as it stands, it runs extremely well in closed loop. I actually tried full open loop once just to compare, and it didn't run any better than my dialed-in closed loop.
That said, if there are "major issues" with the tune, switching to open loop is not going to cure it. For one thing, Power Enrichment, Accelerator Enrichment (and by definition, open loop itself) are areas where switching to open loop won't help anyway.
Old May 21, 2018 | 07:35 PM
japery's Avatar
Car: 1977 corvette
How did you disable the temp setting?
Old May 21, 2018 | 07:38 PM
japery's Avatar
Car: 1977 corvette
I have 10 to 1 compression, better heads and a bigger cam,so the stock bins are giving me problems. its running VERY rich.
Old May 21, 2018 | 07:49 PM
ULTM8Z's Avatar
In TP, do the following.... and then set the temperature to something ridiculous like 300F.
Old May 21, 2018 | 07:53 PM
ULTM8Z's Avatar
Depending on how much "bigger" the cam is (which is really what's going to drive the tuning, much more so than the compression and heads), it's not likely going to open loop will solve all your problems.
What you should do is get a WB O2 sensor on there, hook it up to TunerproRT, then take some data so we can see what your issues are. There are guys on this board who do custom chips... TunedPerformance, MrWilly's, etc... They can take your data and do your retune if you're not up to doing it yourself.
Most likely it'll be a matter of recalibrating the VE and spark tables as well as the open loop and power enrichment tables. After doing those things, and if you're getting hesitation or bogs, then you'd need to work on the accelerator enrichment tables as well.
Old May 21, 2018 | 08:44 PM
japery's Avatar
Car: 1977 corvette
Cam Type: Flat Tappet
.480 Intake .486 Exhaust
229 Intake / 230 Exhaust duration
@ .050
Old May 21, 2018 | 08:48 PM
japery's Avatar
Car: 1977 corvette
And thank you for the help. Not only do I have to learn the software and hardware but I have to figure out how to navigate all the different tuning forums.
Old May 21, 2018 | 09:10 PM
ULTM8Z's Avatar
Yeah, I'd imagine a factory tune having problems with that cam...
I think you can probably stop looking for tuning forums. It doesn't get any better than thirdgen.org for OBD-I tuning.
Old May 21, 2018 | 10:02 PM
Car: 89 Formula
Engine: 383 SBC/HSR
My car idles just fine can drive around town fine, and cold/hot starts are dead on. But I'm using a WB gauge and a Tunerpro RT dashboard with all my data logging gauges on one screen.
I'm not saying it was completely easy, but it was enjoyable and I get exactly what I was hoping for. I wouldn't even try tuning a large cam in closed loop, which is really for fuel efficiency.
ULTM8Z is correct......switching to open loop won't fix major tuning problems.
Old Jun 1, 2018 | 05:57 PM
Mlm0's Avatar
Car: 1989 corvette
Engine: 5.7. L98
Axle/Gears: 3.07
I would like to run open loop at idle. How do I set bin. I’m using ARAP and 6E xdf
Old Jun 13, 2018 | 03:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can raise cl enable temp degrees. This will disable cl until the desired temperature is hit as long as the o2 is warm enough. AFAIK you can’t just have ol at idle it’s all or nothing.
-=Jeff=-
Aug 19, 2001 09:18 PM
IROC-Z_85
Apr 30, 2001 12:38 PM
DSouthern
Dec 2, 2000 10:01 AM
