'7060 PCM problem (1991 G30)
Old Sep 3, 2018 | 12:58 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
1991 G30 van,5.7/4L80E:recently bought this van-runs ok,very drivable,but soft throttle response,exhaust sound a little "off".CEL on as soon as engine starts,pulled codes and got about 20 fault codes when A-B jumpered,CEL will often flicker as fuel pump relay and EGR valve chatter intemittantly-when this occurs,code sequence restarts at 12.Power to PCM is steady and no wiring problems found in the van.Took the PCM apart for a look and all looks good,though I did"reflow"all the soldered harness plug connections with no improvement.Pretty sure a PCM replacement will be needed-just wondering if there is anything outside the PCM I should check or if anyone has fixed a '7060 whith this condition
Old Sep 14, 2018 | 01:19 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Re: '7060 PCM problem (1991 G30)
Got another PCM and that fixed it-now just need to correct the small-cap dizzy ozone buildup problem(will make another thread for that) and all will be well under the doghouse
HighPressure
Mar 24, 2013 05:16 PM
ben73
22
Jan 26, 2012 06:54 AM
guest
Nov 12, 2011 08:31 PM
va454ss
Oct 14, 2008 02:19 PM
Grumpy
Dec 4, 2005 04:42 PM
