'7060 pinout??
Old Apr 8, 2004 | 11:24 AM
ben73's Avatar
'7060 pinout??
Does anyone have, or know where to find a pinout for the 16147060 PCM??
Thanks,
Ben.
Old Apr 8, 2004 | 11:40 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I have it. I'll see if I can find it.
Old Apr 8, 2004 | 05:28 PM
ben73's Avatar
Thanks!!! Please either post a pic here, or send it to me at ben_p@bigpond.net.au if you can.
Thanks again!
Ben..
Old Apr 8, 2004 | 08:53 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I've had no luck finding any wiring info on the 7060 pcm as well.
Old Apr 8, 2004 | 10:01 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
va454,
I would like to swap as well. Not sure if the prominator will work with the 7060 though. How is tuning going with your setup?
Old Apr 9, 2004 | 06:05 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Go here
http://www.megspace.com/cars/16147060/
Old Apr 9, 2004 | 09:57 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I can't see anything on that site, maybe its my browser.
Old Apr 9, 2004 | 10:22 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Its kinda funky. You need to click in the dark portion at the top. I was unsuccessful on my first attempt. Play with it a little.
Old Apr 9, 2004 | 04:20 PM
ben73's Avatar
I can't get to it either...
If anyone can see it, would you mind right-clicking it and 'save as', then post it here for all to see??
Ben.
Old Apr 9, 2004 | 05:20 PM
Brent's Avatar
http://www.megspace.com/cars/16147060/index_tk.html
Old Apr 9, 2004 | 10:30 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Originally posted by r90camarors
va454,
https://www.thirdgen.org/techbb2/sho...hreadid=190424
On page 2, it says it is compatible with the 7060.
Your emails have the answer to your question
Old Apr 10, 2004 | 06:18 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I haven't found a pinout for the 7060 on the net.
If others still haven't I'll type it up, later on today, if needed.
Old Apr 10, 2004 | 07:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here is a list of vehicles wiring diagrams I found at the site va454ss posted above.
LB4 = 4.3L (262) TBI V-6
L05 = 5.7L (350) TBI V-8
L19 = 7.4L (454) TBI V-8
90CKwiring.bmp 90 C/K series LB4 L05 L19 Manual, 700R4, TH400
90RVwiring.bmp 90 R/V series LB4 L05 L19 Manual, 700R4, TH400
Shows 700R4 in more detail
91ck_4l80e.bmp 91 C/K series LB4 L05 L19 with 4L80E
91CK_wo_4L80E.bmp 91 C/K series LB4 L05 L19 without 4L80E (700R4 and manual)
92CK_4L80E.BMP 92 C/K series LB4 L05 L19 with 4L80E
92CK_wo_4L80E.BMP 92 C/K series LB4 L05 L19 without 4L80E (700R4 and manual)
95CK_454Wiring_MT_(x).BMP 95 C/K series L19 (454) with manual transmission
95CK_Wiring_4L60E_(x).BMP 95 C/K series LB4 L05 with 4L60E trans
95CK_Wiring_4L80E_(x).BMP 95 C/K series LB4 L05 L19 with 4L80E trans
95CK_Wiring_MT_(x).BMP 95 C/K series L05 with manual trans
Does the C/K series truck with the 4L60E/4L80E use the '7060 PCM?
RBob.
Old Apr 10, 2004 | 08:28 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Let's see if this works.
http://members.sigecom.net/smaster/7030.jpg
I scanned it and it's large. Also have drawings with and without 4L80E. This was used it many years it seems.
Old Apr 10, 2004 | 08:33 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Short version:
Old Apr 10, 2004 | 09:26 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by SMasterson
Short version:
7060.
I believe it uses two 32 pin connectors.
Old Apr 10, 2004 | 09:55 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Well, could be, I'm just guessing what vehicle this is for.
With the 4l80e it has one 24pin connector and one 32pin connector, according to the diagrams I'm looking at. But, so does the diagram I have without the 4l80e. There's also a TCM listed for transmission control for a diesel.
It would help a bunch if I knew exactly what it was used in but basically I found the ...7030 listed for 90-95 Chevy trucks in the PROM data reference.
I'd be glad to look it up and post it if I had more information.
Old Apr 10, 2004 | 10:08 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
C11 Serial data
D6 Diag test
C2 Ground
C3 Ground
C13 O2 Ground
C14 O2 input
D4 5v ref MAP
C10 Map
D2 MAP/TPA Ground
D15 Trans Temp
C4 5v ref TPS
C5 TPS
D3 TPS/Coolant Ground
D16 CTS Sign
B12 A/C
C6 IAC A Hi
C7 IAC A Low
C8 IAC B High
C9 IAC B Low
D1 Battery
A1 Fuel Pump Relay
D7 Fuel Pump Signal
A7 SES
A4 TCC
A3 Solenoid A
A2 Solenoid B
B7 Force Motor Low
B8 Force motor High
B4 Range signal A
B3 Range singal B
B2 Range signal C
A+B are the 24 Pin Connector
C+D are the 36 Pin
Old Apr 10, 2004 | 10:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by Grumpy
7060.
OK, the file 95CK_Wiring_4L60E_1.BMP has two 32 pin connectors.
The file 92CK_4L80E.BMP has a 24 pin connector and a 32 pin connector.
RBob.
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
RBob.
The 7060 was used in 91-92-93.
Auto Applications only.
But, there are several other options for pcms/ecms, mixed in there.
Old Apr 10, 2004 | 10:14 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Heck, was close,
Old Apr 10, 2004 | 05:47 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
The way I found mine was at www.Car-Part.com. You can find some with a very reasonable price; I paid ~$50 to my door.
Do a search for a 91 with 454 and auto.
As mentioned, several other apps use them, but it was always used with the 480LE, regardless of engine size.
When I converted from the 8747, I had to modify the connectors slightly by removing a couple of the alignment tabs.
Old Jan 26, 2012 | 06:54 AM
sparkinnissan's Avatar
Re: '7060 pinout??
Does any1 still have a pinout with the 4l80e
InfernalVortex
Apr 20, 2021 11:31 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
va454ss
Oct 14, 2008 02:19 PM
Doward
Feb 1, 2003 06:59 PM
