Possible bad ECM or underlying issue.
Old Jul 21, 2019 | 02:50 PM
89T/A_p's Avatar
I know you guys are tired of seeing ECM & injector pulse questions but i couldn’t find a post here to answer mine problem. Recently purchased an 89 T/A w/ 305 TBI setup. Was told by previous owner that the car has been sitting up for years. I’ve been trying to start the engine for a few weekends now. My initial problem was no injector pulse. I swapped the fuel pump, ICM, & TPS. Neither solved the issue. The car would crank with starter fluid and then die because of the injectors not pulsing. I borrowed an ecm, swapped the prom and viola. The injectors pulsed but the car would not stay running. Went out today to crank it and it ran for all of 30 seconds no problem. It stalled and now the injectors no longer pulse. I have ruled out the vats. Wondering if anyone has run into a situation where their car was causing ECMs to go out. Please help.
Old Jul 22, 2019 | 08:53 PM
GeneralDisorder's Avatar
Re: Possible bad ECM or underlying issue.
I would be looking closely at the wiring to the ECM and the pins, etc on the ECM connectors. Sounds like you touched them and it worked and then stopped. You can also verify powers and grounds to the ECM, and check alternator output, AC ripple, etc.
GD
Old Jul 22, 2019 | 10:05 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Second that^^ Something is shorted or burning up....
enswrob
Apr 15, 2010 02:26 PM
skate4music
Feb 11, 2009 07:17 PM
BushyTea
Sep 26, 2008 07:56 PM
tyrvidar
Jan 17, 2007 07:37 PM
j dezzy
Oct 4, 2006 12:01 PM
