How to tell if you have hit the Rev-Limit stop fuel
Old Oct 5, 2019 | 06:48 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
'165 computer running a modified APYU base code on a Superram. Ran great on longtube TPI. With Superam I raised the shift points in the trans to 6100-ish. Hard to get that precise, but 6000RPM was my target. The 1-2 shift is fine - happens at 6000-6100 in TunerproRT. The 2-3 shift doesn't happen - AT ALL. But what it does is get up to 6300-ish and then flutter up and down 1-200 rpm.
My Rev-Limit stop fuel is set to 6514 RPM with a return at 6387 RPM. It feels like I am stuck in this zone and the trans won't shift.
I'd expect the engine to rev up more than it is, if the problem was simply a Trans not shifting issue. The fact that it kind sticks around 62,6300 suggests it's being limited.
Now ... any idea what data point to look at to verify I am at the fuel cutoff limit? I don't see any values. The Inj Pulse rate doesn't change.
I'm going to tweak my govenor and lower the shift point 200rpm or so ... see if that solves it. A bit hesitant to raise the fuel cutoff number.
Mark.
Old Oct 7, 2019 | 12:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: How to tell if you have hit the Rev-Limit stop fuel
As a test just raise the limit way up.
It could be that the valve springs are floating (valves actually).
RBob.
Old Oct 7, 2019 | 08:45 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
Thought about that ... but was looking for a data point.
I'm doubtful on valve float. Edelbrock RPM's from back in the day ... overkill for a TPI engine. But you never know.
I was trying to find the code the the $6E hac to see what it did with the Rev limit ... so far no luck finding the part of the code.
Old Oct 7, 2019 | 09:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
But you aren't running TPI... And valve springs do get tired.
Code:
FA99:  LFA99     LDX     #$0000                ; zero out fuel
FA9C:            STX     L00E0
FA9E:            STX     L00C9
RBob.
Old Oct 17, 2019 | 08:48 PM
tequilaboy's Avatar
You should see the injector pw go to zero during fuel cut. If necessary for testing increase the hysteresis between the off rpm and on rpm points to extend the duration of the fuel cut event so that you can capture it clearly in a datalog to see what is really happening.
I've used 2,000+ rpm off/on hysteresis to serve as a no-lift/no-clutch/power-shift feature. With such a significant rpm drop, you can't miss it (even without data).
RJMcEachern
Jul 28, 2014 02:48 PM
ben73
Jan 5, 2005 08:06 AM
87irocz350
Jun 3, 2002 10:38 PM
drive it
Feb 27, 2002 01:26 AM
giovanhalen
Jun 30, 2001 10:32 PM
