Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
I need help with my shift points
Old May 31, 2002 | 08:10 AM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
I have a 87 iroc with a 350 tpi with a t5 3.42.
My shift light went out on the car before I got it.
For good gas mileage I usally shift around 2,500 rpm.
When Im racing I shift at 4,000 rpm.
Are these good shift points or do I need to use new one.
Please post what you guys do.
Old May 31, 2002 | 08:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Shift points depend on where your engine's powerband is. A TPI engine doesn't pull much above 5500 rpm. Keep trying higher shift points to find the best one. I would say 4800-5200 would be a better range.
A perfect driveline combination is shifting a couple of hundred rpm above the engine's peak HP and going across the finish line a couple of hundred rpm above the shift point.
Old May 31, 2002 | 10:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Actually I thought TPI's stop breating at 4500 rpms??
Though with the steep 1st gear, I would say shifting @5k would be ok for the 1-2 shift, then 4500 rpms on the 2-3. Just experiment and find out what's best. That's why I find the G-Tech a very useful tool.
Old Jun 3, 2002 | 10:38 PM
91_350TPI's Avatar
Car: Lucky Dog Racing 1992 Chevrolet Camaro Z-28
Engine: 379 cid Chevrolet race engine
Transmission: Coam TH-350 w/ transbrake
I did some experimenting with my 91 350 GTA and found that the best shift points for my car was 4700 1-2 and 4500 2-D. Something I was unable to try though, and I think it may have made a difference, was shifting 2-D at around 4200 - 4300. I tried making both shifts at 5000 first and then went to 5000 and 4800 and improved. Then went to 4700 and 4700 and improved a little more and finally went to 4700 and 4500 and improved yet a little more. The only reason I couldn't try bringing the 2-D shift down more is that the car automatically shifts at 4500 whether I shift it early or not. I bet it would help the car though. Hope I helped a little. Drive on...Damien
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
