help with 7727
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
help with 7727
I was wondering if anyone could point me in the direction of the most current hardware/software required to connect to a 7727 via USB/Serial and at least download all relavent tuning data. I'm not looking to modify the tune right now, just download whatever changes have been made in spark/fuel tables. I bought a '90 Vette this past summer thats been upgraded with AFR heads/Comp roller/SuperRam. Whoever did the work obviously did some tuning on the ECU to match, because it runs great. I just want to see whats in there.
I've worked with Megasquirt and Holley EFI, so I have basic familiarity with this stuff.
Thanks,
-Dave
Thanks,
-Dave
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: help with 7727
$8d mask downloads can be found on tuner pros site or gear head efi.
Car: check
Engine: check
Transmission: check
Re: help with 7727
I think what you are looking for is Moates Burn1 to read the PROM. He also sells a header to be able to read the PROM via the Burn1 without removing the PROM from the MEMCAL (HDR-1?).
From there can then use TunerPro to view the contents of the calibration.
RBob.
RBob.
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: help with 7727
You can download the latest version of S_AUJP here supporting $8d and be up and running quickly. The included XDF file provides access to every item in the calibration along with descriptions. The provided ADX logging of all activities.
https://www.thirdgen.org/forums/diy-...-released.html
