Ecm egr fault code
Old Mar 22, 2020 | 07:29 PM
sportster57's Avatar
Ecm egr fault code
Swapped v6 for v8 with original 4l60e and electric egr valve. Drive for miles and as soon as you let off the throttle throws the code for egr. You can’t get on it as long as the check engine is on or the tranny goes into limp mode. Please Help!
Old Mar 22, 2020 | 10:48 PM
Camaro91327's Avatar
Car: 1991 camaro RS
Engine: 408 Stroker
Transmission: 4L80e
Re: Ecm egr fault code
May not know the answer but what V8 is it?
Old Mar 23, 2020 | 05:30 AM
sb350 with throttle body injection
Old Mar 23, 2020 | 07:02 AM
Car: 1991 camaro RS
Engine: 408 Stroker
Transmission: 4L80e
Ok, the most common test is to have the car idling and gently push on the diaphragm inside the EGR. This should cause the car to have a rough idle or die if it doesn't something is blocked and needs to be cleaned out. Here is a website with more information on the EGR system and different tests you can try.
http://shbox.com/1/4th_gen_EGR.html
ohiotemplar
Jul 9, 2008 06:13 PM
gthmcty1
Jun 3, 2005 05:27 PM
EYEROCK89
Mar 22, 2003 08:48 PM
junkcltr
May 28, 2002 12:37 AM
