Name that plug.. next to ECM
Old Apr 18, 2020 | 03:57 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
Can I remove this? I'm removing the ecm and wiring from my car, carb conversion already completed.
Old Apr 18, 2020 | 04:05 PM
Drew's Avatar
Re: Name that plug.. next to ECM
C207. Google it. C207 site:thirdgen.org
Old Apr 18, 2020 | 04:14 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Thank you! I'm reading that it includes some ignition mentions... is it safe to disconnect and remove the plug? I'm running a 6al with billet dist.
Old Apr 19, 2020 | 10:28 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I can't tell you what that plug is doing NOW,.. but here's how it was delivered from the factory.
1988-1989 C207
PIN Color From / To (Notes)
A Brn ALDL (pin C) / ECM (AIR control)
B* Pnk (Red) INJ1 TBI (TBI)
B* Pnk/Blk (Pink) INJ1 (V6)
B* Pnk/Blk (Black) INJ1 (TPI)
C* Brn/Wht ECM / CE Light
D* Brown (Tan/Wht ) Fan
E Wht/Blk ALDL (pin B) / ECM (test)
F Pnk/Blk IGN fuse / ECM
G* Pnk/Blk (White) INJ2 TBI (TBI)
G* Pnk/Blk (Pnk/Black) INJ2 / (V6)
G* Pnk/Blk (Black) INJ2 (TPI)
H Tan/Blk ALDL / TCC-ECM (auto)
H Tan/Blk ALDL / Upshift (stick)
J* Org ALDL (pin E) / ECM
K Brn/Yellow (brown) ECM / Buffer
L Drk Blue (purple) Vats to ECM
M Blk/Wht VSS,P/N switch / Grd
N Org/Blk ECM / P/N switch
P
R Ppl/Wht Crank Fuse / Cold Start-ECM
Old Apr 20, 2020 | 09:47 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Might want to check the cooling fan (D) and the ingition fuse (F). If your are running the stock cooling fan and ECM control, that may be doing something. Otherwise, since you are independent, old school carb and ignition, I'd say nothing on that connector is doing anything for the powertrain anymore. Just my opinion. Can't say for sure. Maybe just unplug it and see what happens.
Old Apr 20, 2020 | 07:15 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Thanks guys, wealth of knowledge as always!
S10K20
Jan 26, 2016 12:27 PM
Ripped
Aug 29, 2007 09:00 PM
HiPerf_Chevyman
Jul 6, 2007 03:43 PM
BobbyK
Sep 9, 2004 10:58 AM
