Fitech wfi install on tbi engine
Old May 5, 2020 | 11:01 AM
Dcm1511's Avatar
Car: 1992 camaro rs
Engine: 87-95 tbi truck engine
Transmission: World class t5
Hey guys im new here. And desperately need help 1992 camaro rs with an 87-95 tbi truck replacement engine
headers, 3 inch exhaust. Im going to be removing the ecm. Havent decided if i will remove completely or move wiring off to the side. Im installing fitech efi easy street 600hp system along with a dual plane weiand intake and hei dist 3 or 4 questions
can i wire the fuel pump power wire from the new system directly to the stock relays wiring?
Can i also do this with the fan relay? The system controls fuel pump and will send the proper voltage to prime and turn on the pump but will this work since i am removing the stock wiring to everything but the required things to basically run a carb and those relays? T5 transmission. So no issues there. And can anyone help me figure out exactly what wiring i need to remove and what can all be kept please. Any help is appreciated i cant really find much and im losing it! Haha. Thanks guys!
Gunreaper
Alternative Port EFI Intakes
Feb 18, 2019 09:39 PM
fonzie85
Jul 16, 2015 07:46 AM
91greenbird
Oct 31, 2008 06:27 PM
87rock
Carburetors
Sep 16, 2006 01:23 AM
