24x with factory tpi
Old Jun 5, 2020 | 09:14 AM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Will the 24x crank trigger distributorless ignition work with a factory tpi? I know the 7730 ecm needs to be changed to an LS ecm and some of the pinouts need to be swapped around. I haven't found any articles online about tpi with 24x anywhere so not sure if anyone has done it.
Old Jun 5, 2020 | 01:11 PM
GeneralDisorder's Avatar
Re: 24x with factory tpi
What do you mean exactly by "factory TPI"? The LS ECM's are sequential ignition/injection and you'll have to wire the crank trigger, coil packs, etc. Basically the stock harness will be of little use. You mean the manifold? Sure it's just a manifold. You can bolt whatever sensors and injectors to it that you want. If you mean will it work with the factory wiring - no.
GD
Old Jun 5, 2020 | 02:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Easier to start with ls1 harness, strip it down and repin the firing order and injector order. Lengthen cam and crank wires to run the 24x efi connection kit and cam sync
Its not terrible to do with the right tools and diagrams just takes some time
Old Jun 7, 2020 | 04:30 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
The '7730 ECM will handle distributorless ignition (DIS). Just need to know the required Reference Angle, maximum allowed advance and maximum allowed retard. S_AUJP v6 "must read me.docx" provides DIS guidelines here: https://www.thirdgen.org/forums/diy-...-released.html
Old Jun 9, 2020 | 09:37 PM
Car: 1991 red Z/28
Thanks for the info. I have to find someone to tune my 7730. That’s something out of my pay grade.lol
Old Jun 10, 2020 | 02:42 PM
Can do if you want to bring it up to my DynoJet in Portland.
GD
Old Jun 10, 2020 | 08:30 PM
Car: 1991 red Z/28
GD
I have to order all my parts to do the 24x conversion first. It'll be a while. I was going to get the EFI conversion kit from EFI Connection, coils (not sure which ones yet), wiring to the coils and to the 24x crank sensor.
Old Jun 10, 2020 | 08:52 PM
What is the reason for going to DIS? What problem are you trying to solve by making those changes?
GD
Old Jun 12, 2020 | 11:14 PM
Car: 1991 red Z/28
Drivability. I can't get it to not stall after coming to a stop unless I give it gas. And the idle isn't consistent. Almost stalls then high idle. Its getting old. It runs fine when I'm out on the freeway going 70mph.
Old Jun 12, 2020 | 11:54 PM
You just need tuning. COP ignition isn't going to fix any of that. You need the TPS and throttle stop adjusted correctly and the IAC control setup to handle your desired idle speed, gear load, and accessory load.
GD
Old Jun 13, 2020 | 10:00 PM
Car: 1991 red Z/28
GD
Thank you GD. I will have to take it probably down to Sacramento and have someone work on it there. There is noone here in far northern California that knows anything about TPI.
Old Jun 13, 2020 | 10:56 PM
It's only about an hour farther to bring it up to me in Portland. No sales tax and in general everything is cheaper in Oregon. Just saying.....
I have all the equipment to tune that and you are unlikely to find any shop in Sac that is owned by a Third Gen lover. I have an 86 Trans Am and a 91 Formula. And a DynoJet for tuning.
GD
Red 87 GTA
Jan 3, 2011 10:13 PM
Black_Knight
Dec 22, 2009 01:59 PM
tbair
May 22, 2005 08:49 PM
