TPS after EBL Install
Old Jul 18, 2020 | 07:12 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
My TPS only gets up to 3.5VDC with KOEO, same occurrence with a second TPS. I did tap into the gray 5V reference for my MAP install.
What should I bee looking for that could affect my voltage. The tap in for the EBL should be a parallel circuit.
Old Jul 18, 2020 | 07:20 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: TPS after EBL Install
Is this with the key on engine off while sitting in the drivers seat pressing on the accelerator pedal observing the WUD, or are you physically opening the TPS lever with your fingers under the hood while measuring voltage? If you're sitting in the drivers seat and flooring the pedal, and the TPS percentage is not reaching where you need it to, then adjust this area in the bin;
TPS - ADC Gain Term for TPS
- Rob
Old Jul 18, 2020 | 07:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check that the go-pedal is actually fully opening the throttle at the TB. A stretched throttle cable or even a floor mat under the pedal can prevent true WOT.
Note that the at-idle TPS voltage can be anywhere between .4 and .8 volts. The EBL auto zeros the TPS.
RBob.
Old Jul 18, 2020 | 08:10 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Thanks again guys, I will get to troubleshooting this later today.
Yes, this is from the drivers seat using the pedal. Also, that is good to know on the auto zero. I have it at .5V right now because that was the setting for the 88 I have always used.
Old Jul 18, 2020 | 09:00 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
After checking for voltage at my MAP and TPS plugs and finding 4.5V. I plugged everything back in and checked WUD again from inside the car to find the same condition.
So I put the lap top on top of the car and went under the hood so I could see my meter and the WUD. Reach over to pull the trottle and then I see it.
See these clamps, nice and aligned
Yup, looks appealing but...
Sometimes you just have to laugh. See, I assumed it was something I did wrong with the wiring because I don't like doing wiring. We all know what happens when you assume.
Vinscully50
May 11, 2020 08:28 PM
Ronny
May 6, 2005 02:52 PM
BP89IROC
Jan 21, 2002 10:48 AM
