TPS Adjustment. No Voltage
Old May 10, 2020 | 11:53 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
So I want to check my TPS sensor, since my car seems a little sluggish from 20 to 60 MPH and a little less responsive. I stuck my multimeter into the back of the TPS pigtale with negative on top and positive just below it and nothing in the third. I got no voltage. I kept trying to wiggle the multimeter leads around but still no voltage. The car was set to run but no reading from the TPS. Just 0.00.
Does this mean the TPS is bad?
Old May 11, 2020 | 09:55 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Re: TPS Adjustment. No Voltage
Could, could mean you are not getting the probes in to a contact area. Are you able to find your 5VDC reference voltage?
This is why it is nice to have a data logger/scanner that you can hook up to the ALDL port and see what the ECM sees.
When my 86's TPS went down, it would only idle. Had to idle it home from about 2 miles away. That took a minute.
Old May 11, 2020 | 10:01 AM
GeneralDisorder's Avatar
You are almost certainly testing wrong. Use proper back-probes and watch some videos on how to properly test 5v sensors.
GD
Old May 11, 2020 | 11:21 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Grey 5v ref
blue tps signal back to the ecm
black ground
Old May 11, 2020 | 01:47 PM
Engine: LB9 305 TPI
Do you know of a good scanner for our ECMs? I guy I worked with when I was a lube tech had a Laptop hook up for his C1500 but said the software sucked and rarely used it.
I'm willing to give it a try.
Old May 11, 2020 | 01:58 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I use both WinALDL and Tuner Pro RT... just depends on what I am doing. There are also other options out there, but both of those software packages are free... just need to buy or build a USB to ALDL connector and have a laptop.
There are also OBD1 scan tools that come up for sale on Ebay, around here, and other sites.
Old May 11, 2020 | 08:15 PM
Snap-On MT2500 "Red Brick" scan tool. Lots of them out there for relatively cheap.
Newer one's work also - I have a "Zeus"..... but the entry price will really put a damper on your next round of performance upgrades. I got mine on a repo deal at about a 40% discount. Still pretty painful.
GD
Old May 11, 2020 | 08:28 PM
NoEmissions84TA's Avatar
You can carefully push common pins through the wires you wish to test, and use alligator clips between the pins and the meter leads. Place the pins far enough apart so that they cannot short to each other (or ground out).
In your case, you want to probe blue to black. But to make sure your meter is reading correctly, probe grey to black first to make sure you have (and are able to read) 5v there.
DAIGS1985
Jul 10, 2008 05:11 PM
abcx09t
Aug 28, 2003 07:17 AM
polishdevil
Jun 17, 2002 09:22 AM
BP89IROC
Jan 21, 2002 10:48 AM
