730 $8d iac issues
Old Sep 17, 2020 | 02:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
730 $8d iac issues
Hello, just wondering if anyone has experienced iac issues with the 1227730 ecm.
Tuning a car for a guy and iac won’t move in part but starts to move in drive.
Old Sep 17, 2020 | 03:52 PM
ULTM8Z's Avatar
Re: 730 $8d iac issues
Does he have 0 STEPs in park, and then something greater than 0 in drive?
Old Sep 17, 2020 | 05:58 PM
Engine: Lb9
Transmission: M20
160 in park and slowly lowers in drive but never really drops real lower than 99 last idle log I watched.
Old Sep 17, 2020 | 06:35 PM
ULTM8Z's Avatar
Ok so the opposite. Did he close his throttle blades or something? Seems like the IAC is trying to supply all the air rather than supplementing the air that should be going through the throttle blades.
Maybe have him go through the idle reset procedure.
Old Sep 17, 2020 | 06:48 PM
Engine: Lb9
Transmission: M20
I’m wondering if it’s a quality control issue with a first throttle body.
I had him go through the minimum idle procedure then set the tps.
Not sure how he could of pulled the iac plug it’s buried under the throttle body between runners.
ill question him some more. I told him he could also watch iac count warm and lower down to 20-25 counts.
i does have a rather large cam that’s making it difficult to tune.
Old Sep 21, 2020 | 05:49 PM
GeneralDisorder's Avatar
I also had some issues with my IAC connector not making good contact with the FIRST throttle body orientation. The severe change in IAC valve position stretches the wiring and changes the angle of the wires coming out of the plug such that it caused connection issues with the wiring and plug from 1986. I replaced the IAC plug and a good section of the wiring with newer, more supple wire and resolved that issue.
It is possible to dig around in there and unplug the IAC but really not needed. You can also remove the TB and get at it that way.
GD
anesthes
Jun 4, 2017 10:32 AM
Tuned Performance
Jun 15, 2013 10:54 PM
Doward
Dec 1, 2004 02:45 PM
Jim85IROC
Jun 11, 2004 08:16 AM
