Distributorless Ignition for 7730 ECM
I'm starting to think about this... The experience I had with that Accel HEI module kinda opened my eyes about how much spark energy can contribute to performance. It's too bad it failed so soon... and I don't want to go with any aftermarket module again due to the notorious unreliability of these things.
So any rate, I'm wondering if should just go whole-hog and go DIS.
I searched and read through a few threads on the subject, but honestly my head is spinning on what to do. I'm trying to see if there's some sort of clear concise step-by-step, here's what you need to buy, here's what you need to do, etc.
One guy at the end of this 4 year old thread said he had a bolt on kit, so I PM'd him just now...
https://www.thirdgen.org/forums/diy-...ml#post6100548
But is there anything else available?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Distributorless Ignition for 7730 ECM
* Crank Trigger
* Oil Pump Drive in lieu of the distributor (LT1), or modified distributor shaft (SBC)...
Click Here for 7730 Pinouts and additional information....
... below are some videos for encouragement.
- Rob
Engine: 4++,350 & 305 CIs
I think I have seen that done on a 165 ECM too. It was a loooong time ago though and I'm getting a bit fuzzy.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
* Coil Pack
* Crank Trigger
- Rob
https://www.youtube.com/watch?v=eR5Uyctp0YE
https://www.youtube.com/watch?v=8sCM1BjlVy4
* Crank Trigger
- Rob
-- Joe
Originally Posted by anesthes
How do you mount an LT1 oil pump drive in a SBC? There is no flat spot to bolt it down in the lifter valley.
-- Joe
-- Joe
- Rob
