ECM Bench and ignition Module Question
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
I don't have an extra ignition modulr for my ECM Bench yet, but I want to just apply power to the ecm and verify I can communicate with it. Basically like if I was testing it in the car, Key On, Engine NOT running. Will I hurt anything by not having the module? I don't think it will be an issue, but wanted to double check before turning the power on.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: ECM Bench and ignition Module Question
you shouldn't have any problems doing that.
Engine: LT5
Transmission: ZF6
Engine: LT5
Transmission: ZF6
