91 Camaro RS 305/starts stops starts stops 🤨
Old Apr 15, 2021 | 04:43 PM
PapaRoach3's Avatar
I have a 91 Camaro RS 305 and I'm having problems starting it I've had to put a jumper wire on the Anti-Theft module just to get the starter to kick over security light stays on. For that matter I replace several new components modules relays fuel pump wiring new lock cylinder with the vat system bypass the vats system with it resistor setup of 887 and the security light is still on please help???🙏.. just finished putting in a smog pump it froze up.. I've also put in a new ignition switch turn signal lever with the multifunctions and all that works from that is the mist part of the windshield wipers it has cruise control delay dimmer and none of those work so I'm not sure what I did wrong.. if anyone can help it would be great especially with the ECM or ECU if you can reset it or not????
mjones89
Sep 28, 2013 08:11 AM
1998TA__1991RS
Aug 10, 2010 09:22 PM
bdm91camaro
Jul 2, 2010 10:33 PM
91camarorsripde
May 19, 2010 07:33 PM
joepackersrock
Oct 12, 2008 05:46 PM
