EBL Flash w/Crossfire L83 Engine....
Old Aug 20, 2021 | 11:17 PM
  #51
Buccaneer's Avatar
Car: 82 Corvette - CFI
Engine: 383 - Renegade, AFR 195, Bullet cam
Transmission: 700R4 - 3,200 Yank TC
Axle/Gears: 3.31
Re: EBL Flash w/Crossfire L83 Engine....
Originally Posted by Street Lethal
Tom, I think he was talking about the EBL analysis screen shots that I added above during the logging. He might be looking in the Wideband column and seeing extremely rich values. That's mainly because I don't have my wideband connected directly to the EBL system, but I do have it checked off in the EBL Preferences tab which is why it is showing a value, albeit a rich value. Cartrax, ideally you will want to focus on the INT/BLM values with the above logs. However, for wide open throttle using a wideband, you will want to shoot for a 12.5 to 12.8 AFR.... naturally aspirated.
- Rob
OK, Gotcha Rob.
Old Aug 24, 2021 | 02:51 PM
  #52
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Originally Posted by Buccaneer
I take it you are running an EBL, right? So you can tune it, right? 8-10 is pig rich.
Running EBL, yes working tune...
Old Aug 24, 2021 | 02:53 PM
  #53
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
- Rob
Me too, got it.
Old Aug 24, 2021 | 06:20 PM
  #54
Buccaneer's Avatar
Axle/Gears: 3.31
Hey Rob, I was thinking that I may be able to maybe starting the tune again now that I'm back from vacation, but as luck would have it, the temps are going back up this week to the 110*-112* degree range again. Ugh! Much to hot to play around. So, it may be another couple more weeks before I can start things going again. I do have a game plan for the new WB controller though and maybe I can get that installed before the tuning starts again which would be helpful.
Old Aug 24, 2021 | 06:42 PM
  #55
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
We're getting hotter temps here as well, the next three to four days are going to be a scorcher. Once we resume the tuning, the new game plan is to make your crossfire the fastest naturally aspirated crossfire on the planet. Then hopefully you'll consider going the boost route next...
- Rob
Old Aug 24, 2021 | 09:11 PM
  #56
Buccaneer's Avatar
Axle/Gears: 3.31
- Rob
That's awesome...and I just literally laughed out loud.
Old Aug 25, 2021 | 10:44 AM
  #57
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Talk about lethal - this partnership will be
Old Sep 9, 2021 | 10:08 AM
  #58
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Replaced my "nice and shinny" fuel hardlines with braided fuel line hose and new fittings. The hardlines were causing some issues with the new tune. I've seen this issue happen on two other CF cars, a 82 and a 84. After replacing the lines, the issue goes away. I guess you could install a fuel damper, but that would be just that much more modifying and finding the right part and I didn't want to do that. The new hose is a simpler fix IMO. Just in-case someone else wants to do this, this is how I did it. Enjoy!
BEFORE
AFTER
I would like to buy those parallel plumb fittings
Old Sep 9, 2021 | 12:48 PM
  #59
Buccaneer's Avatar
Axle/Gears: 3.31
Won't do it, not for sale.
Old Sep 9, 2021 | 03:47 PM
  #60
KITT1983's Avatar
I'm talking these
https://www.xfireperformance.com/sho...-fuel-fittings
Old Sep 10, 2021 | 09:13 PM
  #61
KITT1983's Avatar
How come ?
Old Sep 13, 2021 | 02:38 PM
  #62
84 4+3's Avatar
Car: 84 vette
Engine: L83
Transmission: Dougnash 4+3
Axle/Gears: 3.08
I just had to pop in per Tom's reccomendation... I may have gotten a few ideas for fixing my own mill just reading through...
Glad you all have a solution hammered down. I still have a perfectly functional 84 manual ecm. Idk how you could read any calibration data off of it but if we could... I'd gladly lend it out to help out if it does. I've also toyed with the idea of seeing if the car would even run with a stock ecm put back in it... that was the original build plan but... I may have over corrected.
Old Nov 16, 2022 | 09:47 PM
  #63
Chrismurray187's Avatar
Originally Posted by NotaVetteGuy
Very nice work! I reached out to Bob for the L83 tune to run in my 84' crossfire corvette. Works excellent! Good throttle response and very snappy.
I do have a question tho.. Were the test mule cars all automatics? I have a 4+3 and the engine is unsure on what to do when I push the clutch in and the car is still moving. Idles around 1200 rpm while coasting to a stop, but at a dead stop settles to 950-1000 rpm after about 15 seconds or so. Thoughts?
Anyway to share the tune for an 84?
Old Nov 17, 2022 | 09:13 AM
  #64
Buccaneer's Avatar
Axle/Gears: 3.31
I have a 84 4+3 tune if you want it. PM me with your email.
Old Nov 18, 2022 | 08:43 AM
  #65
TPIShark's Avatar
Yo, anyone hear from Street Lethal lately? He dropped off the radar a couple weeks ago, and I'm concerned. Thanks.
Old Nov 18, 2022 | 09:11 AM
  #66
Buccaneer's Avatar
Axle/Gears: 3.31
I need to contact him as well and I have been trying since last weekend to include text messages with no reply's to anything. Hope all is well...OR maybe he is on vacation?
Old Nov 27, 2022 | 10:10 PM
  #67
Buccaneer's Avatar
Axle/Gears: 3.31
ANYBODY?
84Elky
Nov 24, 2021 10:43 AM
K1ng0011
Jul 29, 2018 06:55 PM
Darkshot
Nov 25, 2007 10:25 PM
HowdyDuty
Jun 13, 2007 06:58 PM
Ronny
Apr 11, 2006 11:13 PM
