Ref Period oscillating at High RPM under load - Help
Old Jul 21, 2021 | 04:34 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Deleted
Old Aug 6, 2021 | 10:36 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Ref Period oscillating at High RPM under load - Help
Could be crankshaft resonance propagating to the cam drive and through distributor gear.
since it appears to repeat at the high speed and load areas, the tolerances of the timing chain, distributor gear may be showing. Heavy power stroke pulses bouncing the chain?
long shot but tossing ideas,
oil pump relief bouncing may also load/unload the distributor shaft just enough to cause a fluttering that only shows in between power strokes.
Would be good to track over time to see if the amplitude of the oscillation increase to show wear.
Jp
Old Aug 7, 2021 | 08:01 AM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Delete
FireDemonSiC
32
May 23, 2018 07:02 PM
ladreamer
Mar 23, 2015 09:20 PM
junkcltr
28
Jul 21, 2008 02:19 PM
IRACE87
May 27, 2005 05:43 PM
precision350
Feb 13, 2002 06:16 PM
