DFI and ECMDiscuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
I wired in the sensor white analog positive 0-5+ wire to D8 on the 165 ECM but can't get a reading in Tunerpro.
It says the BROWN wire must be connected to the negative of the analog input of the logging device or ECU. If the logging device or ECU does not have a differential analog input (both a dedicated positive and negative terminal for the analog input) then connect the BROWN wire to the shared signal ground. If the device does not have a dedicated signal ground then as a last course of action, connect it to the power ground of the logging device.
That is the trouble I am having. Does the 165 ecm have a negative analog input? Or does the brown wire just hook up to chassis ground? What do they mean by Shared Signal Ground? Does the Brown hook up to a GROUND pin on the ECM??
