1987 iroc ecm issue?
Old Feb 4, 2022 | 08:12 PM
RandyFlip23's Avatar
Hi I have a 1987 camaro iroc and I think there is a issue with the ecm, the car is getting power and cranking however when I turn the key to the on position the engine light is not illuminating and the injectors aren’t getting power.. I recently picked up the car and I noticed it has a remanufactured ecm.
Old Feb 4, 2022 | 08:57 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: 1987 iroc ecm issue?
Replacing it and see if it fixes your problem would be the fast and easy way to test that.
ECMs don't die very often. I have had a car with a faulty ECM (but it didn't fully die). The no SES light makes me suspicious of a poor ground or lack of power somewhere. Things you could check:
  • verify power at the injector fuses
  • verify top of the fuse box is clear of debris
  • verify signal from the distributor to the ECM
  • verify all the parts that have been replaced are installed correctly
The diagnostic flowchart for this issue in the factory service manual (not Haynes) could be helpful.
motoj550
Jan 13, 2021 04:49 PM
atreju
May 25, 2018 01:48 AM
skeltor
Feb 2, 2016 10:37 AM
Chevy86 IROC-Z
May 27, 2010 04:41 PM
