Testing AFR gauges and sensors
Old Oct 17, 2023 | 07:26 AM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
I just watched an Engine Masters segment on the Motor trend website which provided some really good info. They tested five different gauges to see how close they read. Also tested this: If you have a dead sparkplug and the cylinder pumps raw fuel into the exhaust does the AFR gauge read richer? No! Several other tests were also done. Watch the video to see the results, you will be surprised. Many other good tips also.
Old Oct 17, 2023 | 10:26 AM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: Testing AFR gauges and sensors
Do you happen to have a link? I can't find it.
Old Oct 17, 2023 | 12:21 PM
Rebuildman's Avatar
Engine Masters | Watch Full Episodes & More! - MotorTrend
Hopefully that gets you there.
Old Oct 19, 2023 | 02:14 PM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
agreed solid watch. Also surprised leaks did not make a mahoosive difference
Old Oct 20, 2023 | 05:58 AM
Rebuildman's Avatar
Yep, good information that is proven on the dyno. How many threads have beat on exhaust leaks being the cause of problems?
Hmmm, gets you thinking about it at least!
The raw fuel in the exhaust not causing a rich reading is also something to remember.
O2 sensors read oxygen content only! Does not care if it is bathed in raw fuel!
Something I think people forget.
Little nuggets of good information.
Old Oct 20, 2023 | 08:34 AM
dabomb6608's Avatar
I find it rather surprising that their testing showed leaks having no negative effects....the same publication had this article out back in 2018 stating the very opposite.
https://www.motortrend.com/how-to/ex...nsor-readings/
Old Oct 21, 2023 | 08:21 AM
Rebuildman's Avatar
Ha! That's funny, Steve Bruhl(?) ran the dyno on both occassions!
Seems like the latest dyno testing was all from 3000 rpm and up, no idle or cruise rpm checked.
Exhaust pressure blowing out of the leak instead of sucking air in?
Guess that's the thinking behind the latest test.
The earlier test has to be correct also.
Leaks are bad at lower rpm's especially, and more so when in a lower pressure part of exhaust flow.
Old Oct 21, 2023 | 04:23 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Good info thanks!
J0hn_J0hn08
Jun 29, 2010 03:49 AM
88ROC1LE
Aftermarket Product Review
Apr 21, 2003 05:06 PM
jm91rs
Jan 23, 2002 04:23 PM
