What would happen?
Old May 5, 2025 | 11:54 AM
Vhanta97's Avatar
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
What would happen?
I'm about to get my hands on a 1994 GMC Suburban 1500 with TBI SBC 350. I want to move as much of the drivetrain as I can into my 1984 Berlinetta. What would happen if I carried the TBI and ECM over to my Camaro?
Old May 5, 2025 | 12:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What would happen?
what would happen ? Do you like to do wiring ?
Old May 5, 2025 | 12:42 PM
Vhanta97's Avatar
Axle/Gears: Stock
I'd like to avoid any additional wiring, but I'm just wondering if it would affect anything if the drivetrain thinks it's a suburban rather than a Camaro.
Old May 5, 2025 | 12:44 PM
Engine: Lb9
Transmission: M20
joking right?
Old May 5, 2025 | 12:46 PM
Vhanta97's Avatar
Axle/Gears: Stock
joking right?
Trying to cut corners here, get the most out of an $800 suburban.
Old May 6, 2025 | 07:45 AM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
A: You can't perform this swap without doing additional wiring. Especially going into a 1984 car.
B: The drivetrain doesn't "know" what vehicle it is in, per say. You can run the Suburban tune without any large issues. It would be more dialed in however to use a prom from a car.
C: Speaking from experience here...the goal of cutting corners is never a good starting point or ending point for that matter.
rwlightner
Mar 5, 2025 05:56 PM
jrws6
Sep 24, 2009 02:16 AM
tttpicamaro
Dec 9, 2007 09:16 AM
