91 TBI to 88 TPI
Old Feb 4, 2002 | 07:33 PM
1991 RS 305's Avatar
91 TBI to 88 TPI
I am picking up a TPI system off a 88 Firebird. I will be putting it on a 1991 RS 305. My question is will the ECM and harness from the 88 TPI hook up to everything on my car once the TPI is installed, will it create any problems with the airbag? Should I buy the harness and ECM from a 91 Camaro w/ TPI, or will the 88 work just fine?
Thanks, all help is greatly appreciated!!
Matt
Old Feb 5, 2002 | 01:28 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 91 TBI to 88 TPI
Matt
using the 91 is the way to go. there are some differences thou. The 91 is MAP based instead of MAF. There is no plug and play to get the 88 into a 91 that I know of. the 91 system is worth the effort.
Old Feb 5, 2002 | 02:36 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, your VSS may cause a problem. The 88 MAF systems can't handle the 4000 pulse/mile Magnetic Sensor used on the later model SD TPI. I am not positive on your 1991 TBI, but it too uses the Magentic VSS like the TPI cars, then you will need to address that issue if you go MAF.
Conversley, if you go to the 7730 SD ECM, like Grumpy suggests ,it won't matter as it supports both. Also, the 7730 is a dime a dozen at the wrecking yards. Many early 90s 3.1 V6 cars (except W bodies) used the 7730. Cavaliers are a good example. Also, you can grab the harness and use parts of it like the connectors.
Old Mar 22, 2002 | 11:18 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
almostthesameswap!
i have an 89 TPI 5.7 in my 91 TBI Firebird.so would you say you cannot plug and play with the 89 and 91 together?if i got an 90-92 TPI harness i can plug and play?
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
