? about DFI Gen VII
Old Apr 11, 2002 | 01:42 PM
Bobalos's Avatar
? about DFI Gen VII
I was reading through the Car Craft May issue & they did a carb to EFI comparison & they used the new Gen VII ECM & software. They said:
"DFI's new Gen VII Windows compatible software was installed in a laptop computer, basic setup parameters were entered, and the engine started and constucted its own baseline fuel curve - just as ACCEL advertised"
this implies to me that it has an auto learn feature. Has anyone run this & does it really work as advertised? does it also have a closed loop feature as well?
Tanx
BW
Old Apr 11, 2002 | 02:37 PM
aDFIguy's Avatar
Car: GTP
Engine: L67
The Gen 7 DFI does have an autolearn feature.
Really, you just enter your engine and fuel system parameters, then the Volumetric Efficiency Predictor utility constructs a base fuel map that will be good enough to safely start and run the motor.
Yes, it does have closed loop fueling capability, the wideband O2 sensor is optional. In fact, even when running in open loop mode, the ECM will still fuel your engine based on the settings in the target air to fuel ratio table. It calculates an estimated MAF based on the volumetric efficency of the motor.
More info & demo software:
http://mrgasket.com/dfimain.html
Old Apr 11, 2002 | 06:29 PM
Bobalos's Avatar
Very intersting. I would guess that the Fuel table still needs to be tweeked in, if it "estimates" rather than "learning".
Thanks for the link, I will check it out.
BW
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
