MEM-CAL questions
Old Apr 15, 2002 | 07:34 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
MEM-CAL questions
I just got my SD 1227730 ECM and MAP sensor today for my MAF to SD converstion. The MEM-CAL in the ECM is a "ASMJ 0692". Here is my questions how do i know if it has the right limp home chip for my engine? Not for some other car that GM used the 1227730 ECM on. I dont care about the ASMJ chip b/c I am going to burn over it, just worried that if the ECM goes into limp with this MEM-CAL that it will not have the right settings stored in the limp home chips to run my engine. Are all the MEM-CAL's the same for the 1227730?
Old Apr 15, 2002 | 07:43 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Go here --> http://holman.cs.uml.edu/~sdurphey/b...b.cgi?BCC=ASMJ
It's for a 88-89 2.8 V6 Beretta...can't be used on a V8 car.
You need the AUJP Memcal
Use that link that I gave and plug in "AUJP" for the proper part number.
In the early 90s, most SD L98 F-bodies ran the AUJP1350. The current replacement Memcal is now the AUJP1615...but it's idential except for the "date and sequence number". But that link will give you the proper GM Part Number.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
