Cable and a Laptop
Car: 1987 Camaro
Engine: 383
Transmission: Built Up 700-R4
Cable and a Laptop
Ok, I am new to proms and scanning. I have a 1987 Z28 with the Q-Jet Carb. It was a 305, but now has a 383. I simply want to hook up a cable and scan with a laptop. I mainly want to see my knock sensor and timing retard. Being a carb car, I doubt I will try burning, but I would like to somewhat learn what is going on.
Also, what type of chip/ecm to I have? Is it completly different from the TPI TBI types? Or should I even care if I am just hooking up to the ADAL connector.
Thanks for the help, I was thinking of trying to use a Moates cable and TunerCat, would this work for what I want it for? I looked around, and I could never find how to make my own cable, any links or diagrams would also help.
Thanks,
Bill
Car: `86 SS / `87 SS
I posted the ECM number here: https://www.thirdgen.org/techbb2/sho...hreadid=100245
I too will be looking to be able to scan the CCC stuff.
Car: An Ol Buick
Engine: Vsick
Re: Cable and a Laptop
It uses a 2716 prom, which is not erasable, so you kill one with just one burn.
The CCC has been gone over repeatedly, and a quick search should answer any CCC question you have. There just aint much to the ecm in one.
Originally posted by Grumpy
There is no freeware for scaning a CCC ecm with a laptop.
Thanks for the info on the 2716's
Matthew
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
