Making HUGE changes...what do I do for the computer???
Old May 6, 2002 | 08:11 PM
CamaroX84's Avatar
Well, right now I have the stock TPI and heads with a mild street cam in my 355. I am getting a Holley Stealth Ram, AFR 195cc heads, and an agressive street/strip cam. I know nobody will be able to hit the nail right on the head for a perfect PROM for a setup like this, but could you guys give me an idea as to what I have to change and by about how much? I want to get a PROM that is acceptable to even start the engine with. I'm pretty sure I can't use my chip now, as it is very close to stock. I'm assuming this because I would think that it would run waaaaay too lean and could possibly cause engine damage. ANY help would be greatly appreciated. Thanks in advance.
Old May 7, 2002 | 01:04 PM
kvu's Avatar
kvu
read up on the arap bin
Old May 8, 2002 | 04:19 PM
CamaroX84's Avatar
Where can I get this bin? Is it compatible with the 730 ECM? You think it will actually be close enough? Thanks again.
Old May 23, 2002 | 03:30 PM
CamaroX84's Avatar
I just did some research and the ARAP bin is only for MAF cars. I have the speed density system. Any other suggestions? Thanks.
Old May 23, 2002 | 05:06 PM
AlexJH's Avatar
Engine: 5.7L V8
Have you read programming 101 on the DIY-EFI.org website?
Old May 23, 2002 | 05:10 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I believe you are looking for the AUJP1350 bin.
http://www.diy-efi.org/gmecm/ecm_info/1227730/
may want to look here too. cheers, Bob
Keith5
Aug 27, 2015 04:37 PM
Bryan F
Aug 18, 2015 02:28 PM
matthew911
Aug 12, 2015 09:38 AM
z28addict8490
Aug 7, 2015 08:48 PM
