What next after part throttle tuning on the P730?
Old May 19, 2002 | 05:54 PM
camaroguy99's Avatar
Well, I have gotten almost all of the attainable BLM's to within 1% of 128 (good enough for me). What should I takle next and how should I go about it? Spark tables? PE? Please give me some guidance. Thanks.
Jim
Old May 20, 2002 | 01:38 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: What next after part throttle tuning on the P730?
You have to work timing and fuel together.
If you have a solid baseline, then establish exactly what it is performance wise, and then try moving the WOT fuel and timing around. If you start seeing knock retard then note where and remove some timing in those spots.
Remember, you want to run the least amount of timing consistant with best performance.
NOT
The greatest amount of timing possible.
They are two very different concepts.
Old May 20, 2002 | 02:17 PM
craiger's Avatar
I too have the blm's right at 128. Now, time to adjust the timming tables then make the blm's 128 after the changes. So what is a good timming table to start with for the $8definition file in TC? ARAP is a $6 so is the AUJP bin similar? Also, once i get a timming table to work with, should i decrease the timming table? or should i increase it till i get some knock counts, then back it off? Thanks for the help!!!!!
Old May 20, 2002 | 07:28 PM
Thanks Grumpy. I do have a quick question about knock retard. It's taking about 7* out around 4000 RPM under WOT. Can I simply subtract the 7.0 from the total timing in the appropriate cell? or do I need to take it out in small increments untill it disappears? Thanks again.
Jim
Old May 21, 2002 | 07:45 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Jim
I'd take out a couple degrees of advance at a time. When the computer takes out timing to control knock, it has to take out a good bit more than necessary in order to snuff it out since it's harder to put out once it's started.
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
