Speed Density MEMCALs
Old May 25, 2002 | 12:57 PM
jnjspdshop's Avatar
Anyone have any idea where to get some cheap MEMCALS for a SD 5.0 & 5.7 Camaro/Firebirds 90-92??
Does anyone have any for sale. I have a **** load of AT29C256 and I am looking to mod a few MEMCALS so I can program and switch on the road
Jay
Old May 25, 2002 | 02:41 PM
Wilson's Avatar
Why dont you just modify your Memcal now and solder in a DIF socket. When you want to do tuning just install a low-profile ZIF socket ontop of the DIF and you can swap out prom's whenever you want. It'll be cheaper then buying multiple Memcals. Brand new Memcal's cost $42 bucks. Did you try checking the local yards and see if they have any?
Old May 25, 2002 | 10:32 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
What's a DIF?
Old May 26, 2002 | 01:34 PM
Wilson's Avatar
Originally posted by Craig Moates
What's a DIF?
I meant DIP socket. I think Craig's design also uses a DIP socket on his adapters and then a ZIF socket ontop that for easy swapping. When you finally get the your program the way you like it just remove the ZIF socket and insert the prom into the DIP. That way you'll be 100% sure the prom will never wiggle out.
88SS6SPEED
Nov 11, 2015 07:05 AM
85 Jimmy
Sep 30, 2015 07:56 AM
lethaldomestics
Sep 21, 2015 01:18 PM
RGB2015
Sep 20, 2015 09:26 PM
