Fans run all the time/cold start injector with arap bin questions???
Old Jun 13, 2002 | 05:41 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
My 86 Tran Am has the single fan & the cold start injector. With the car cold & ignition on the fan does not spin. As soon as you crank the car up within 5 seconds of running the fan starts. Is there a problem with the arap code & a 86 single fan setup?
Second problem, what shuts the cold start injector off?? When creating the prom chip with the arap code, I dont see anything with the cold start injector.
Can I just disconnect the wires at the cold start injector or do I need to block off the fuel going to it? My idle goes up & down from 1300-1000rpm regardless of motor temp. I have the fan set to come on at about 195F. I can also smell a really rich exhaust. I tried setting the Air Conditioner enabler N/O on.. but the fan still has a mind of its own.
Whats the normal O2 reading at idle with the car warmed up?
Old Jun 13, 2002 | 05:48 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Just disconnect the Cold Start.. Need to compare the wiring diagrams from yours to a 89 running dual fans and see what output the ECM uses to control the fan. cheers, Bob
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
redmaroz
Aug 16, 2015 11:40 PM
