what should the pulse width normally be?
Old Jun 14, 2002 | 11:05 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
the pulse width is about 1.8 ms at idle and increases to 4. someting when accelerating hard but after letting of completely the pulse width will go to 0.0 for a good 5-10 seconds. What is going on with that? Also, my 02 readings fluctuate from 100-800 range all the time. It's a real quick kinda thing where they are always just fluctuationg in that range. Is this normal?
Old Jun 15, 2002 | 09:56 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: what should the pulse width normally be?
1.8 ish at idle is fine.
You can see PWs as long as 20 msec depending on what your doing.
0.00 on deccleration, means you've hit the DFCO. Deccleration Fuel Cut Off.
The ecm toggles the AFR across 14.7:1, it doesn't try to maintain a 14.7:1 AFR. So you'll see the O2 voltage flucuate.
Old Jun 15, 2002 | 11:32 AM
Greg's Avatar
What about the O2 cross counts . . . I can just watch that number go higher and higher. There is a count about every second or half a second. Is this normal? And my car is staying in closed loop once it warms up, I thought it was suppost to go to open loop at WOT. What voltage is needed for it to go to open loop at WOT? Thanks
Old Jun 16, 2002 | 06:15 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Yes, you should see the cross counts gradually rising.
WOT is a special mode, while the various scanners don't report a change in loop status, it does go open loop at WOT.
There are several perameters for going closed loop.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
