Irap Urap we allrap for ARAP!!
Old Jun 17, 2002 | 03:15 PM
tpi_roc's Avatar
< /lame >
Ok anyways
I've made a hybrid (muwhaha) aujn timing with arap fuel and I just had a epiphany as to why I have a rich idle. Could this be that the ARAPs "extravagant" fuel tables mated with the AUJNs "conservative" timing lowered the idle timing so much that I'm not getting a complete enough burn thus a "false" rich idle so to speak?
The idle corrects itself enough to be of little concern in closed loop, but in open loop its just to rich.
Old Jun 17, 2002 | 03:57 PM
goneracin's Avatar
I would guess that is the case. Late timing will put extra unburned fuel in the exhaust, making the comp think its rich, when its just late timing. Try to advance timing in the tables, but just at idle conditions, this should help.
Bob
Old Jun 17, 2002 | 04:27 PM
tpi_roc's Avatar
That will be tonights task then. Assuming I get that nailed I'd recommend this bin to anybody as a sollution for the ARAP.
Old Jun 17, 2002 | 04:30 PM
AlexJH's Avatar
Engine: 5.7L V8
I did the same thing, but ended up with a lean idle.
Old Jun 17, 2002 | 05:20 PM
tpi_roc's Avatar
Did playing with low LV8 timing fix that for you?
Old Jun 17, 2002 | 06:57 PM
AlexJH's Avatar
Engine: 5.7L V8
No, I fixed that with the batt voltage corrections.
Glen
Apr 19, 2003 10:03 PM
madmax
31
Jan 7, 2003 04:15 AM
Mark 89Formula
Jun 25, 2001 10:20 PM
Grim Reaper
May 23, 2001 08:08 PM
P J Moran
Apr 20, 2001 06:11 PM
