Just finished 165 to 730 swap, but now
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
After repinnig, adding new wires for map sensor, jumping est wires, and countless DAYS of trouble shooting I'm still getting code 33 and a nasty idle that'll make you throw up. I've went thru the entire harness from front to back and back to front over and over again, but still the same result "nothing" same old code 33. I was using two map sensors from junkyard, so I figured they where bad so I went to the story and purchased a new one still nothing changed. Checked for vac leaks at the intake and hoses, nope no vac leaks either.
List of mods: The biggest thing that I believe is my problem is my cam size, not enough vac for map to pick up without me using a program rewritter and not just Tunercat..
Cam:224,224@.050 and 528,528 lift
Heads: Stage 2 G1 Twisted wedge 309 cfm @ .600 llift
Block:ZZ4 crate motor w? 10.7 to 1 compression
Intake: Mini Ram II w/ 58mm TB
Can someone HELP?
Can someone HELP?
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
