Why do 94+ camaro's have a MAF and a MAP?
Old Jul 31, 2002 | 12:28 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Why do 94+ Camaro's have a MAF and a MAP? Do these computers have VE tables and MAF scalar tables then? What is the benefit of having both? Is it to get a more accurate fuel mixture?
Old Jul 31, 2002 | 02:38 AM
Morley's Avatar
I was told that they run off of the MAF unless something goes wrong with that system, then it failsafes to the MAP system.
Old Jul 31, 2002 | 07:47 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
That, and
there was at one time some doubt about when OBDII was going to be implimented. So they were at one timing gearing up for a earlier intro then 96. Some 94-96 applications have both OBDI and OBD II stuff in them.
In the OBDII world the PCM, must be able to verify things mush better then the OBD! stuff so the MAP is used to verify the MAF readings are about right. Well at least in theory. Some guys have 0'd out the MAP tables and noticed no change in the way the car runs.
On a 95 8051 we converted it to MAP only and there was a slight gain, but it took lots of work. We didn't try at the time to rehash the MAF scalers and table. Do it wasn't a completely fair comparison.
Old Aug 1, 2002 | 04:33 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
89 Iroc:
I just made a lot of tests running my 1988 MAF+MAP A-body car in MAF only, MAP only and MAF&MAP with different masks. You can read it at V6 forum/ Sticky: "Attention ALL V6...".
Regards,
Denis V.
92camaroJoe
Jul 29, 2023 07:57 PM
NBrehm
Aug 25, 2015 11:49 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
