which is the right prom to order?
Old Aug 5, 2002 | 11:27 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
according to trax's article the 89 ecm needs a 27C Eprom, at the jadeco site they have these but listed with either a -12 , -15, -20, -25 which one is correct or what is the difference in them?
Old Aug 5, 2002 | 02:17 PM
Bort62's Avatar
Get the AT29C256's from JDR.com
The 27's are not Flash Proms.
Old Aug 5, 2002 | 09:57 PM
monte-ss's Avatar
other than being the flash prom is the AT29C256 the same as the 27c128?
Old Aug 6, 2002 | 12:11 AM
Guest
Guest
Posts: n/a
No, the 128 has half the memory of the 256.
Old Aug 6, 2002 | 12:57 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you mean that the part numbers were 27C1228-12, 27C128-15, 27C128-20 and 27C128-25 then that is the speed (response time) of the chip. -12 = 120 nanoseconds and is faster. -15 = 150 nanoseconds, and 20 = 200 nanoseconds, etc. Faster usually (but not always) is more $. Slower works fine in these.
If you use the 27C series you will need to use a UV eraser to clear the chip. If you use a 29C256 it is electronicaly erasable, but has twice the space as a 128, and you will need to program your 16k bin into the last (upper) half of the chips addresses.
Old Aug 6, 2002 | 09:34 AM
monte-ss's Avatar
programming the upper half?
ok how do you program the upper half of this if the car was orriginally designed to work on the 128, do you just fill it with garbage, or will it actually use the info to do it that way? if I can use these and erase them electronically then it saves me from having to purchase the eraser.
Old Aug 6, 2002 | 10:39 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Get the flash, save your money on the eraser. Just 'stack' the bin, look around on the site, you'll see reference to it.
Old Aug 6, 2002 | 11:40 AM
monte-ss's Avatar
I found an article on stacking the prom after I had made that last post
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
jaridjohn
Oct 5, 2015 07:01 AM
dusterbd
Sep 29, 2015 08:40 AM
